Do i have the right size of fuse in my power wire?
ckunke002
I know there are other threads on this topic, but I'm reading mixed reports so I want to get this clear.
Last week my fuse next to my battery blew, and I didn't know anything about fuses so I just took it into my local car audio shop and let them pick me out the proper fuse. I did a little bit of research after I got home and I'm not sure they gave me what I need. I'm running 4 gauge power wire, and they upgraded my 60 amp fuse that popped with a 200 amp fuse. To my understanding, my 800ish watt system only draws 50/60 amps of current and I can't imagine a 200 amp rated fuse protecting anything when hell breaks loose in my wiring system.
How many amps is 4 gauge power wire designed to carry and how does one determine the fuse rating they need? I've read in a few threads that fuse amp rating must be higher than amp's amp consumption (efficiency) but lower than the number of amps that the specific size of wire can safely carry. Is this correct?
Thanks anyone and everyone
Copy paste from bcae1.com
Suggested Fuse SizesWire Gauge Recommended
Maximum Fuse Size
00 awg 400 amps
0 awg 325 amps
1 awg 250 amps
2 awg 200 amps
4 awg 125 amps
6 awg 80 amps
8 awg 50 amps
10 awg 30 amps
12 awg 20 amps
14 awg 15 amps
16 awg 7.5 amps
These are the recommended maximum fuse ratings for the corresponding wire size. Using a smaller fuse than what's recommended here will be perfectly safe.
200A is way too high for 4g wire.
Do you think I could go into the shop and tell them that they gave me the wrong size and replace it with a 100 amp fuse?
Depends on the shop. I would certainly take it back and ask about it as well as asking why they gave you a 200a in the first place. Depending on length of run that could get your wire pretty **** hot if you had a partial short.
Ive ran 4ga in several vehicles, and I recommend the largest of a 150,more than 100 ANL of course..200 will start melting the coating on the wiring, and possibly the plastic under the dist block if you have one.Thats too much.120-150max
So the fuse is for keeping the amperage running through the wire down AND protecting the battery?
The fuse is there so when the amperage gets to high it burns the fuse instead of letting the wire get hot and melt.
Amp is the current, and watt is the power.
If you know you're only going to be using 50-60 amp and your wire is rated for 125 amp, it's safe to go with 80-100 amp fuse.
So unless I'm getting near the point of fuse breaking then it's all the same, right? For example, my wires aren't in more danger with a 200A fuse than a 100A fuse if I'm only running 40 or 50 amps through it? Or is that incorrect?
I'm not suggesting it nor anyone here would recommend it, did you figure out why the fuse blew? It's always better to be safe than sorry.
Having the 200 amp would be fine if you're planning on upgrading the wires in the future.
That heatsink's shape, color, and plexi bottom is just like the US Amps. I like it.
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
980
Hello, I already posted in general but wanted to also post in here. I recently installed a set of used JL audio shallow depth 12W 1v3-4 inside an...
ckunke002
ckunke002
Portland, OR
HardofWhoring
audiobaun
    May 19, 2024
    May 19, 2024
