Thrift store build
billythegrape
CarAudio.com Newbie
Since the build I had at: https://www.caraudio.com/threads/weird-build-questions.612498/page-2#post-8829958 worked out so well (thanks to everyone here!), I need help with equipment recommendations.
I want to add two 6" by 9" speakers, a four channel bluetooth receiver (not a stereo for a car with a screen), and a sub. I have included diagrams at the bottom and am open to suggestions.
This is what I currently have:
Vehicle:
1988 Chevy G20 Explorer conversion.
Head unit:
Whatever phone is connected to the BT adapter, which is an Esinkin Bluetooth adapter.
Speakers:
Rear: Two 6" by 9" Sony xplod 4 ohm 240w. Mounted in a red oak cabinet above the rear bench seat.
Two 6.5" inch rounds Dual 4 ohm 160w. Mounted in plywood above the middle seats.
Front: Two 5.25" 4 ohm 100W Recoil RCX525 speakers from amazon. Mounted in the lower portion of the front doors.
Amp:
JVC KS-AX3104 800w
Wiring:
All brand new. See diagram. Rears are wired in parallel.
Not sure what your head unit is, but all of those speakers are 40-60w RMS. You can get a 4ch x 50w RMS head unit, and you won't need to use a second amp for speakers. It looks like you have a 4ch amp and a 2ch amp. So not sure how you were going to run 4 sets, but if you haven't bought a bluetooth adapter, that offsets the cost of that a little. If your current head unit doesn't have 3 sets of RCA outputs then you need some kind of signal splitter.
We're you going to run a sub off that dual amp? It's 150w x 1 @ 4ohms (bridged). That's pretty small, but with a small powered sub, it'll work.
So if you wanted just a 150w into one sub, then all you need is a new head unit, instead of a new amp, and a bluetooth adapter.
The only stuff I used is what's listed above. I'm using just the one jvc amp. Really what I need is a recommendation on a Bluetooth receiver with a 4 channel output to match the amp input. I don't need a screen since I just use my phone anyway.
From the looks of things, by far the easiest thing to do is to get a Bluetooth head unit. You don’t have to get an expensive one with a touch screen, their are budget single din units that will do everything you want for not a huge amount of money.
Looks like I called this one correctly and OP hasn't been back to post any glowing reviews either.
21
5K
Well, I've owned probably over 100 different drivers in the last 40 years and almost every single speaker in the NVX line-up over the last 8...
16
668
https://www.youtube.com/@therealmatty_s/videos
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
863
I got to message a DD woofer builder a decent bit my last stent of box designing; they would send me designs to do for or with individual...
5
742
billythegrape
CarAudio.com Newbie
billythegrape
Knoxville, TN
1aespinoza
winkychevelle
    Apr 27, 2024
audiobaun
    Apr 27, 2024
Latest topics
