Does a Line Output Converter need to be wired up to both sides of the car for a sub?
Ha, I grew up in La Mesa, GO BOLTS!
The simple answer is no, you don’t have to. The better answer is YES, it is preferable to sum both channels to one so that you don’t miss out on differences in recorded material from either channel. By taking signal from both R/L your amp then sums them together (MONO) and you get everything intended from the program material.
The correct answer is yes, you want both left and right so you get low end information from both channels. It is very common for recording engineers to use panning to create a soundstage which results in information in left or right channels. Choosing one means you will miss out on the information in the other channel. You also get the bonus of summing two signals which is free signal gain. Always, without exception*, use both left and right channels to feed a sub amp.
*some may say that there can be noise or cancellation issues when using two channels in rare instances but that is from improper install/wiring or damaged equipment and something that should be fixed with proper wiring methods, instead of a band-aid of using one of the two channels.
Most new radios have that feature. Just check that they have 4 RCA outputs. Those are line output. If it only has 2 RCA outputs, make sure they...
38
331
981
10
948
AudioArchitech
AudioArchitech
San Diego
keep_hope_alive
    May 18, 2024
    May 16, 2024
