Jbl model 2205C 15" 32ohm speaker
  • 2
Can I use this antique with a car audio amplifier or not
Sure, power is power. I'd worry that mechanically an antique PA woofer wouldn't really handle all that much power before the cone, surround, or spiders fail, and I suspect a woofer like that is designed to function properly in a bass bin/horn or refrigerator sized enclosure so performance, even if it's in perfect condition, would be lackluster if the correct enclosure will not fit in a vehicle.
On the bright side, 2205 recone kits are readily available for 75$ so if it does fail you can at least restore it.
I didn't see where there was a difference (didn't see a "light" or "lite" version). That said, if you can fit it, then the JBL BassPro SL 2 would...
WANTED JBL 800GTI
Slava Ukraini, Brother! Don't have that amp but good luck and welcome!
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Working with undersized material, adjusting on the fly, testing before setting; you sound like and old pro. You are as meticulous as alot of the...
76
6K
Rondo84
CarAudio.com Newbie
Rondo84
hispls
Doxquzme
    May 22, 2024
1aespinoza
    May 22, 2024
