Rms watts
  • 3
Yes 10 inch duals
then they will be wired to 1ohm. At least that is what they should be wired too. Should be a wonderful match with a little headroom depending on the amplifier.
When setting the gain on the amplifier set all EQ's to flat, no bass boost, no loudness, amps bass knob all the way up. Turn your head unit up to 3/4 volume on most head units and send a 40hz -15db signal to that sub amp. Set the gain so the output voltage on the terminals is at 31.62v. This will give you 1,000w @ 1 ohm with some wiggle room for more volume on the subs.
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
995
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
No issues there. The amp will output depending on the speaker's impedance rating. Are you using a component x-over or is only the tweeter with x-over?
937
Deff a beautiful constructed sub. The best thing about as well, they do perform very well too and have excellent C.Service and even Tech service...
21
4K
bn1856
CarAudio.com Newbie
bn1856
Pekin il
ThxOne
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
