Rms mark.
  • 4
Got the math behind that?
Sent from my XT1710-02 using Tapatalk
With a load being 1 ohm, volts and amps should be equal (On a TRUE 1 ohm load), in which case the math is V/A=1, V*A=2500W, 50Vx50A=2500W
Granted that is with a resistive load. If your reactive load is rising to 2 ohms your VAC need to be at 70.5... however that amp won't put out a VAC of 70.5 as that is beyond its capability at 2ohms....
So...set it at 50??
I don't think this is ideal, but let's assume you can easily mount all the tweeters. That installing them is going to be really simple, and...
13
Running wattage below RMS won't hurt anything. What the speakers get is the same thing as running an amp with higher wattage and then turning the...
14
No issues there. The amp will output depending on the speaker's impedance rating. Are you using a component x-over or is only the tweeter with x-over?
996
Deff a beautiful constructed sub. The best thing about as well, they do perform very well too and have excellent C.Service and even Tech service...
21
4K
The Camry
Hey, I Try.
The Camry
Western Oregon
BOOMINGRANDPA
