Setup for a 350z
I would get some quotes, but if you want snug fit we would need the car or a very very good drawing to go by.
I don't keep any of the trim-plates on file for us as each car is different(even if it is the same make/model/year).
So I'm pretty much stuck with a prefab one then.. ?
---------- Post added at 12:57 AM ---------- Previous post was at 12:56 AM ----------
that depends ,if your close to the us border then you might be able to get around the canadian shipping
Done that a few times, ship to a UPS/FedEx store by the boarder and have the purchaser pick up the item in the US and drive back. Saves a ton of money too.
[quote name='falcons03079313']@Spider Monkey[/QUOTE]
You know I'm not allowed out here bro.,,
[quote name='pro-rabbit']
I would highly suggest some sound dampening of some sort. All of the 350Z's we have ever worked on had an abundance of road noise.[/QUOTE]
True. Especially with the top down.
[quote name='Pholicious']Looking for advice for a budget setup I have 1500$ give or take I'm not sure whether to run a single 10" or two of them I went to my local audio store but they have almost no experience with 350z.
I'm also not sure of what sub, amp, speakers to run. I can get a decent deal on a kenwood dx419 headunit right now so I just need help with the rest.
Sound quality is important to me but I would also like a nice hit[/QUOTE]
Bro, you already have a sick ass BOSE set up. It doesn't get any baller than that.
Here's what I did when I had my Z. There is a large piece of foam in the rear left hand corner that can be removed. Gives you a lot of space for a fiberglass enclosure.
This would go a long way to alleviating the dimming issue, up to around 4000 watts. It can handle 100A continuous and up to 285A 7 second burst...
571
I had some 9500 series 12s by MTX that were some slamming subs!! Should have kept those along with those torpedo RE XXX 12s
15
970
I am doing an all JL audio instal on my new F250 SD . I'm using a Audio Control LC 5i Pro with a JL Audio XDM 700/5 and C3-650's in all 4 doors...
894
Id sit down and figure out exactly what all you will be installing for amperage consumption and add another 10-15% amperage useage on top of that...
21
Pholicious
Pholicious
Canada
richericks
    May 16, 2024
    May 16, 2024
