Sub amp problem
  • 4
Aaron Johnson
Hey everyone. I have a question about my sub amp situation and how to make it work. So atm I have one twelve one amp sounds good. But I bought another amp which isn't the same brand as the original. And bought another twelve which isn't the same as the original. Both the amps are monoblock cea 2000rms. And both the subs are 2ohm 2000 rms. These will be placed in a ported box. All I keep hearing is they will work against each other????????? ANYONE
Your question is too general.
One does not usually put two different models in a shared enclosure if they are different subs.
One does not usually power two of the same woofers in a shared box with two different amplifiers either.
Need to know which amps, make an model.
What are the make/models of each sub.
What is the internal volume of each enclosure after woofer, (braces if applicable) and port displacement.
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned properly may work just fine after tuning properly, but advisable and less work and frustration and tuning to use same subs and a single mono amplifier.
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
643
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
503
Hello all. Used to come on these forum quite a bit. I used to compete in IASCA MECA etc. and placed 1st 2x with this setup. Anyway this is my baby...
Yes on both of these. Splicing means connecting one wire to another. So one wire to the positive and one to the negative wires or terminals of...
866
Aaron Johnson
Aaron Johnson
Evansville Indiana
audiobaun
just call me KeV
    Apr 27, 2024
just call me KeV
    Apr 27, 2024
