Wouldn't smaller driver sizes have higher freq. response?Driver size has no bearing on the sound being "tight" or "punchy". These are things that are vastly more affected by enclosure size/alignment...
Wrong answer.Smaller drivers typically have a smaller xmax, and are able to respond quicker due to simple physics. Cone mass is smaller,and therefore can move quicker.
Check out pro audio stud //content.invisioncic.com/y282845/emoticons/wink.gif.608e3ea05f1a9f98611af0861652f8fb.gif 12-15" mids are common place.If driver size doesn't matter, why not run 15's for mids?
Nope. Sorry.With 8's you trade off super low extention for faster response.
Maybe, maybe not.Wouldn't smaller driver sizes have higher freq. response?
I would, given that I just got bich slapped by someone more knowledgable.MC Wiggles //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif (Dan Wiggins) has written several excellent papers on Mms vs. Le and their effect on "woofer speed"...required reading if you're curious about this //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
This was my logic. I guess I'm just confused and my experience means nothing? Maybey I have never heard a well executed car audio system with 15's that I liked. I never said they don't exist, I've just never seen one in person.Hmm, let's see. A 15" woofer can easily move at 50 cycles correct? Well, then we could assume that say a 1" tweeter can easily move at 20,000 cycles correct? Can the same be said for the 15" woofer? We could also assume that is the tweeter easily moves at this rate, then slowing it down to only 50 cycles would be no problem correct? Why can my tweeters not produce an audible 50Hz tone?//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
If the inductance allowed for it, yes.Can the same be said for the 15" woofer?
Not enough displacement //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gifWhy can my tweeters not produce an audible 50Hz tone?//content.invisioncic.com/y282845/emoticons/tongue.gif.6130eb82179565f6db8d26d6001dcd24.gif
//content.invisioncic.com/y282845/emoticons/eek.gif.771b7a90cf45cabdc554ff1121c21c4a.gifIf the inductance allowed for it, yes.
Beaming would be a ***** at 20khz, however.
