Rethinking my sub choice
4BangerStanger
CarAudio.com Regular
117
DFW
So, after quite a bit of research and discussion on here, I had made my decision to go with single 10" Dayton Reference HO sub. But, now I have it in my head that I might wanna do dual 8" instead. Doing so would allow me to build the box a little shorter, giving me more flexibility on the depth and width. Plus, it'll still be fairly light weight. And, of course a little more cone area wouldn't be a bad thing. The only downside I can really see would be the extra expense of the other sub. The 8" version of the Dayton is only slightly less expensive than the 10". So, what would y'all recommend, a single 10" or dual 8"? I mostly listen to hip hop, but some country, rock, etc. Whatever I choose will be powered by a Taramps HD3000 (1 ohm version). If I do make the switch to the 8s, are there any good options that might be cheaper than the Daytons?
DD 508, AB VFL844, Sundown E8v5 all good choices.
And yes the only difference with the 2 8s is the extra cost and increased cone area.
Thanks. I'm thinking I'll get dual 2ohm models and run the amp at 2 ohms. Do you think that's a good plan? Or would you recommend a different configuration?
Using a Y RCA to split signal from amp to amp to give both amps the signal they need from the HU and subs in different /separate enclosures tuned...
503
https://www.parts-express.com/GRS-10SW-4HE-10-Paper-Cone-Rubber-Surround-High-Excursion-Subwoofer-4-Ohm-292-818?quantity=1 One of these in a...
357
Hahaha his brother got some from a friend. American bass amp and some alpine s 12in subs. From a buddy of his now Eastons chomping at the bit...
498
4BangerStanger
4BangerStanger
DFW
denim
vlusardi
    Apr 27, 2024
    Apr 27, 2024
