So which is the right cut out for orion hcca12 11.5 or 11.9
  • 3
on1wheel01
Bang A Lang
Welp building a box for a orion hcca 122. Looking on orions web site for that sub one place says 11.9 one place says 11.5. So wtf which is it needing to know as im at the process to cut out the holes. Also I'm having a brain fart 11.5 would be 11 1/2 right? And 11.9 would be 11 7/8? Sorry for the noob ?'s I don't know whats wrong with me today
Well building the box for someone and they can't get the dim's so that's the prob. Guess I will go with 11.5 which is figure 11 1/2 and if need bigger will just hit with grinder and sanding pad
Why?
Do they not have the sub yet?
People getting in a hurry to build/do something before they have the gear is the real problem.....
(not referring to you OP)
You should hold off on the build until the customer has the sub in hand so you can do your job correctly.
While we're speculating, why not bump up your volume gain (no pun intended) for just a few dollars more (literally) and go with the 8" versions of...
5
960
Hello, I already posted in general but wanted to also post in here. I recently installed a set of used JL audio shallow depth 12W 1v3-4 inside an...
Makes sense. You may be right on the gain; 2 subs on 300 watts seems anemic.
46
4K
on1wheel01
Bang A Lang
on1wheel01
Mooresville nc
on1wheel01
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
